McG economy or delux
Which would/did you go with. McG deluxe or economy
  • Total voters
    11
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
It all depends on what you want out of your truck. If you plan to run a wide wheel/tire combo, then you need to be careful about the spindles on the deluxe kit pushing your front wheels out a bit. At the same time, the deluxe kit will give you a factory ride quality, and give you the option to go lower than 2/4 down the road.
The economy kit is cheaper, but will ride a little stiffer and you wont have that cushion to go lower down the road without replacing the front coils with spindles.
Both are great kits, but they each have their place.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
The ride on my econo kit is fine and I'm on stock shocks so upgrading would help even more. I chose the econo kit because I didn't like how the spindles pushed the front wheels out with the deluxe kit.
retiredfireman
Maryland
I have the econo kit and like it for the better ride with the heavier springs.
I also went with BellTech shocks for the smoother ride without the stock shocks being compressed
TylerB
FL
I say econo unless you plan to go lower in the future.
Arturo Rojas
