McGaughy's Deluxe 2/4 Drop Kit 09-12 Ram 1500 2WD
cullen17
Fort Carson, Colorado
I'm looking into lowering my '12 R/t and i was wondering what the advantage is with going with McGaughys delux kit with the front spindles instead of the spring kits? This kit also does not include shocks so would it be worth it to buy new shocks aswell? I plan on driving this truck until it dies so i want to get the best stuff i can.
chrisb38002
Lakeland, TN
I will be going with the McGaughy deluxe kit on my 13 RT soon. I had their kit on my 03 for over 8 years (about 90K miles), never had an issue with it.
I like the spindles instead of springs because it keeps all the steering and other geometry the same as stock, and uses the stock shocks and bump stops (at least in front).
I would save the money for shocks and get the adjustable panhard bar for the rear axle. That's my plan anyway. JMO.
Don't forget to post some pics when it's done. :grd:
BlkRamRt
SoCal
HEMI 5.7
adjustable upper and lower bars
KnightXpress
Dallas,TX
I installed this particular kit on my truck and it is badass! Rides great and handles way better than stock also. I left the stock shocks on front and rear and have not had a single issue. The track bar relocator is the part that centers your axle side to side is included. Rear bump stops are easy to put on but the stock bump stop cup that is welded the the perch on the frame is an ******* to cut off. The spindles are also a breeze to install. I do however recommend an alignment after installation. Two thumbs up for this kit for sure.
jcs64
amsterdam ny
2012 4wd
1- stock shocks are fine w/ this setup
2- you don't need the adjustable panhard bar, mcgaughys kit come w/ a relocater that
works great
3- to remove the rear bump stop cups, grind thru one of the welds (which ever one is easier to get to) then use a hammer to keep beating it back and forth till the other weld cracks off, Super easy!
jeff
cullen17
cullen17
I dont have any tools at home i sold them all when i sold my race car so im going to have a shop do all the work ill pay them to cuss at it when they do it. :)
BlkRamRt
SoCal
HEMI 5.7
My belltech 964sp kit came with the track bar relocater and it still needed slight adjustment.
petesnchz
Pomona, CA
2012 RAM EXPRESS SINGLE CAB
Where is everyone getting there deluxe kit? I'm thinking of getting this with my tax refund.
chrisb38002
Lakeland, TN
I am ordering mine direct from McGaughys (mcgaughystore.com). The deluxe kit is $588 with free shipping. I have not found it any cheaper anywhere else so far, especially with free shipping.
I forgot that the kits now include the track bar relocator (they didn't when first came out), but I am still changing to an adjustable. I just like having the ability to fine tune it, but that's me. You would be fine with the relocator in the kit.
cullen17
cullen17
Moes also has the delux kit but its $649 so it is a little cheaper to get straight from mcgaughys and right now there is a coupon code at McGaughys website that lowers the price another $20 so its $568 from them
bskl76
Bako, ca
5.7 liter Hemi
2/4 deluxe kit
I have this kit. It come wid rear panhard relocation bracket so u dnt have to get tht unless it doesn't line up straight cause no 2 trucks r the same. It also comes with rear end links. What I suggest is u get rear spohn upper & lower adjustable control arms to position wheels properly in wheel well
cullen17
cullen17
I got a rough quote of $600 for the kit and then $400 for labor and an allignment after the install. Has anyone ever had a shop install this kit or one like it and how much did you pay for the labor?
