Spend 16 minutes and watch this video,you might change your mind. You need an unlocked PCM / bypass cable,and tune to disable it.While you're at,you'll also want a non-mds cam / 8 non-mds lifters and Ma Mopars mds block off plugs for a 6 speed 5.7 or 6.4 Challenger to properly disable the mds.Hi, is there a plug into the diagnostic port a module to deactivate mds for 2019 ram classic 1500 without having to use the up and down gear selector buttons?
The short answer is no.Hi, is there a plug into the diagnostic port a module to deactivate mds for 2019 ram classic 1500 without having to use the up and down gear selector buttons?
He's got a 2019 "Classic". Were those PCM's locked starting in 2019? I know the 5th Gens are........... You need an unlocked PCM / bypass cable,and tune to disable it......
Chrysler started locking the PCMs in everything starting in 2015,starting in 2018 you need the Smart Access cable on top of an unlocked pcm .He's got a 2019 "Classic". Were those PCM's locked starting in 2019? I know the 5th Gens are........
You can simply gear down manually (on the steering wheel), then run it back up to top gear to disable it.could a Ram owner keep their speed above 75 MPH / 120.701 KPH ?
to keep the MDS from engaging ?
Of course, in Canada an owner may have to have a Traffic Court Judge on the payroll![]()
Depending on what road you're on GT. Some of the secondary highways have a 80kmh/50 mph speed limit,and 120 clics/75 mph will get you taggedcould a Ram owner keep their speed above 75 MPH / 120.701 KPH ?
The QE2 between Calgary and Edmonton is 110kmh's,and i've been on that road with the cruise set at 156 kmh's (that's where the cruise tops out on most Chryco vehicles,lol),and drove by the cops sitting off to the side with no issues during daylight hours,after dark,it's another story though,then you definitely want to slow down
If you thought that video was interesting,you'll really like this 13 minute video,as it goes into detail on the hemi's somewhat substandard oiling system.The video was very interesting and he made several good points.
Everybodies favorite Uncle Tony has a couple video's that are also worth watching.The 2nd one is the better of the 2,but both are worth watching.The video was very interesting and he made several good points.
We look into the Hemi lifter failures and the dreaded Hemi tick
We unpack the lifter oiling issue that plague the late Hemi.Powellmachineinc.comIf you want to support us financially https://cash.app/$PowellMachinewww.youtube.com
You better have,as i've posted it at least a dozen times by nowYep, seen this already ...
. Just kidding J
You better have,as i've posted it at least a dozen times by now. Just kidding J
Thanks for the support J,it's very appreciated. I have a few haters on here,but i really could care less about them,as i'll still try to get info out,whether they like it or not.Rick, don't get discouraged/tired of posting good advice, its greatly appreciated and not everyone knows to search the RAMForum for the ton of info that is already here ...
