Hello all!
I bought a 99 RAM 2500 with the 8L V10 under the hood. It's been a great truck, but it makes some strange engine noise under certain circumstances. I finally got under the truck with someone in the cab to rev the engine up, and I noticed the noise is very likely coming from a metal pipe that comes out near the exhaust on the passenger side. It's around 3/4-1" in diameter, and you can feel a lot of air coming out of it while the engine is running. I did some research and found that this engine doesn't seem to have an EGR system, as I was expecting it was a bypass for that. The previous owner had chopped up the exhaust and I also expect that this line was once plumbed into the exhaust. It's next to impossible to find any info on this on the internet, so figured I would hope someone here would know what this is, and if it should be plumbed into the exhaust?
