Minimal vibration.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Hello y’all,
I have noticed a slight vibration that feels like it’s coming from the engine area and only happens when I rev up to around 2500 RPMs and let off the gas, driving or sitting. Throttle drops and it will give a slight rumble/vibration. The truck is a 2011 And has no cats and heat shields are gone (long tubes). She’s tuned and I have the mds turned off. I’m praying to God it’s not the torque converter starting to go as I just had this trans overhauled! Like I said, it’s not very loud and only happens when you give or step on throttle at 2500 RPMs, any higher it goes away and will do it again once the needle drops back down area 2500 RPMs for like a couple seconds. Normal driving she’s good, shifts and no codes. That’s the only issue and haven’t really had any luck online with looking for a cause of the issue. Any input is greatly appreciated. Thanks.
RamCares
n/a
n/a
Hello y’all,
Hi @Lyle Longboat - Please do not hesitate to follow up with our Canadian Customer Care team if at any point you decide to address this with your dealer. You may either call 1-800-361-3700 or submit your info at https://forms.chryslercanada.ca/contact/en/contactCCI.php?brand=dodge to receive an email follow up.
Mark
RamCares
joshhhh
