Mirriors for a 2014 1500
RamitMan1986
Ohio
5.7l hemi
Whats up guys i have a 2014 1500, i believe its a Express.. my passenger side mirror broke probably just going to replace both, there power motor and heated... question is do the replacements i buy have to be the same way? Or could i get some with turn signals and what not or would i have to buy an adaptive piece?
Ricks Ram
You can install mirrors with the blinker and puddle lights and they will work after the correct codes are enabled in the BCM. No other parts are needed. You can enable the codes with the alfa tool which is an app you can purchase to enable pretty much anything you want (Check out the alfa OBD thread) or you can have the dealer enable the LEB and LEC blinker/puddle codes. If you install power fold mirrors and want the power fold option to work you will need to purchase a different master door switch and driver and passenger side door modules. The dealer cannot enable the LER power fold mirror code because your trucks trim level doesn't allow it but you can easily enable the code with the alfa OBD. If you purchase new mirrors make sure they are for a 13 or newer. The ambient temp sensor is mounted in the drivers side mirror on the 13 and newer Rams.
bmireault1980
