Mirrors with the signal lights
SELARAM12
Downey, CA
HEMI 5.7
im going to be buying some mirrors for my ram express but i want to buy the ones with the signal light on them but they are telling me that the signal light wont work... is there a way i can make them work??
quietpeen
2021 TRX
Hellcat
a lot of what i have seen on here confirms that on the express you can't get the turn signal to work
quietpeen
2021 TRX
Hellcat
sales codes in the computer or something like that. Hopefully somebody that knows for sure chimes in
Big Boi
S. Fla
Cant he just run wires from the mirrors to the turn signals in the heads?
kkreit01
Olathe, KS
^ That's what I was wondering? If you hardwire the mirror lights into your existing turn signals, it has to work. It will take some hacking, and running of wires...
SELARAM12
SELARAM12
Downey, CA
HEMI 5.7
cool what kind of wires do i run?
jlb
MT
CTD
Since the heads are traditional incandescent elements compared to the LED's in the mirror it would probably be safe to wire directly from the heads without even incorporating a relay.
garner
Harker Heights, TX
Pretty much on the 2012 you can not reflash the computer for the turn signals to work. Doesn't matter if it's an express/st or a lonestar/big horn. If you don't choose the luxury group then you're screwed. Maybe you could hardwire but I don't see the point of rewiring a whole truck
SELARAM12
SELARAM12
Downey, CA
HEMI 5.7
so i can connect them to the heads or its a bad idea?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
sure you can. just need to run 1 wire per side from the headlights to the mirrors. Then run a ground close to the mirror.
jlb
MT
CTD
Since you are getting the power mirrors the harness should already include a ground/all the wiring for the turns. Not sure where that harness ends/are you buying the one that comes all the way from the ECU?
You only need to hit the one wire on the harness that is actually for the turn signals with the wire you run back from the heads.
PX8
2013 Express Crew Cab
Yep totally do able. Just make sure you get sidemirrors with LED's so you don't draw a lot of current.
