Misfires Codes and others more
dindopr
Puerto RIco
Hi, i have 2014 Ram 1500 with a few problems. Four weeks ago I changed the gasoline level sensor because of a PCM code. Also changed the sparks plugs( at 93k miles). After 3 day started misfiring with codes p0300 p3401,p3425,p3441,p3449, p0032 t,p0038, p0052, p0058 and others more. I had the lifters and computer(behind air filter) replaced. Now when I turn it on and when is cold she doesnt run well like misfiring fand after a few minutes returns to normal. The engine light still on. Any feedback will be appreciate it Thanks
Burla
2010 Hemi Reg Cab 4x4
Why did you do lifters? Did you check cam lob when you changed lifters? Most of the time the cam lob is the issue.
