Modify Street Gen 2 DRL
Jimmyjoe
Poplar Grove, IL
I’m trying to figure out if the gen 2 drls when they are wired direct to the battery and also being tapped into the F66 fuse should come on when the truck is running WITHOUT having to turn on the parking lights. I thought that would be the case but mine only come on when I turn on the parking lights.
Thanks in advance,
Jim
1500ram12
5.9L Cummins
Double check the connection to the fuse and maybe Try a different fuse. They should turn on as soon as the key goes to acc or is running.
1500ram12
5.9L Cummins
Also check the battery connection
Jon A
Thornton Co
What did you figure out? I'm having the same issue
