Mopar fog lights
DennisD1975
Canada
I am adding oem foglights to my 2021 Classic and was hoping someone could point me where to find the Mopar Foglight Jumper Harness? I have been looking online and have not had any luck. If it was located in Canada, that would be a nice bonus, but will take any links anyone can provide, excited to get my first "mod" done, but hung up on the missing harness at this point. Thanks in advance,
mrack
Which harness, the one in the bumper or the wires on the truck side that go to the tipm and supply power to the fogs?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I think @Mpgrimm2 can make you a custom harness to add the OEM foglights. He sells harnesses for all kinds of OEM accessories.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I am looking for the one from the tipm to supply power and ground
I'm pretty sure @Mpgrimm2 's utilize the OEM paths to operate as if it were installed this way from the factory. From his website:
"Used to complete missing wiring from Mopar Jumper/Bumper harness to connector under PDC/TIPM on 2010-2018 Trucks. Additional user supplied hardware/Sales Code programming req'd.
(2010-12 versions available on limited basis)"
Jimmitch
Tuckerton
There is a place called infotainment. I believe they are located in Florida. I am in the process of ordering the fog light kit for my 2019 ram 1500 classic 5.7. I just installed the correct bumper with the fog light cutouts. Just waiting for the fog lights to come in. they should be here any day. you may be able to get just the harness from them.
inuyasha-rules
WY
The way I wired mine was I tapped +12v off the driver side marker light, and used that to trigger a relay so the fog lights are on whenever the marker lights are. I picked 12v up from a stud in the fuse blox and added a fuse, and ran wires to the pigtails, with a nearby bolt for ground.
Not sure where the previous owner got the parts, but he wasn't good with wires at all. He put in tinted headlights and fog lights, so being able to run high beams plus fog is better for me, so I get a bit extra light down road. The factory system kills the fogs when you put your high beams on.
Nixonjgreg
