RandyRAM2500
Hello. I'm new to the forum and hoping someone can point in the right direction. I recently bought a 2016 RAM 2500 6.7L Tradesman with missing rear sensors and sensor harness (It does not have front sensors). I installed new parts but it still didn't work so I took it to the dealer. The dealer said the module was bad so I have since replaced the module with the same model number module that was in it (PARK ASSIST MODULE 68204477AD) but still no luck.
The ParkSense light on the on/off button remains permanently lit (which I understand indicates a problem) and the dash continues to say service system. What am I missing? Is 68204477AD the right module? Do I need to drive it? Is there a fuse I should check other than the ones under the hood in the fuse box?
Thanks in advance for any help you can provide.
