Mopar Lift Kit Help!!!!!!
Nanuk
NEW JERSEY
2011 RAM 1500 Big Horn Crew Cab
Hi all , I've been posting on several different location regarding this kit and no one has answered ...,
I have on my 2011 Big Horn CC 4 x4 2" ready lift spacers , truck now has a reverse rake about, 3/4" , main cause I believe is that it has a leer cap installed.
Question : Has anyone used this Kit which contains
2 front adjustable shocks 2 rear shocks , 2 rear springs and all necessary brackets for brake hoses and sway bar .
Like so many have said "Don't do it twice ", like I'm doing don't go spacer route it's a waste of time adjustables just are mor economical in the long run .
Thanks for the help
N
Nanuk
NEW JERSEY
I didn't mention that I also purchased air lift 1000 to help this problem ,only to throw good money over bad , was another quick fix . I don't mind a slight rake , but would like total truck raised about 2" , front and rear .
Towing becomes an issue if your level , coil springs squat more then leafs .
Thanks again. I just want to get it right this time .
