Morimoto headlights
LoneStarSilver
South Central Texas
I’ve been looking at all the different brands of lights,bulbs and reading all the information, good and bad, and made a decision that, I feel gave me the most bang for my buck. I chose to try the Supernova V.4 in my low beam quads. I would love to get my hands on a lux meter to get numbers, but there is night and day difference from the halogens. One issue I was concerned with was blinding oncoming vehicles, so I makes 4 friends with 4 different vehicles to drive towards me. No problems whatsoever. I am sure that the fact that the LED’s are clocked at 3 and 9 o’clock makes the beam pattern almost identical to the halogens. It lights up the ground much further down the road and MUCH brighter which is what I was looking for. The pure white light they emit is so much better than the dull pale light the halogens produce. We recently had many days of rain and the V.4’s really do well to light up the wet road, unlike the halogens.
My only complaint, and Headlight Revolution has been working with me on this, is that I had my DRL’s turned on about 6 months ago and they worked great with the halogens. The LED’s do not like them!!! There must be something in the CANBUS that doesn’t like the reduced power of the DRL’s in this application, so during my oil change and recall work I had them turned off.
The fact that the V.4’s are so much brighter, and give me what I was looking for, I probably will not invest the $1,000+ cost of the fantastic looking Morimotos.....unless someone will lend me a pair to try and I see a significant difference. My next purchases will be the high beam and fog light LED conversion.
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
Installed the morimoto rocklights this weekend to go with the headlights
Reactions: JB1
Arcangel06
Another XB melting case.
Five months in. Adjusters are NOT broken that I can tell. Projectors do NOT shake in housing. This is present on BOTH sides outer projectors. Im also noticing a candle type flickering on the driver side side marker .
Joemagnum
Brandon mb
Joemagnum
Brandon mb
It's ********. 1400 lights and this is what you get
I know... I had to get that one replaced because of wires hanging down in front of the projector and now I noticed those markings. Aaaand my drivers side isn’t level. It flares up on the ditch side
bellaireroad
Fort Worth
I have it on my passenger side too. It is on the black part, looks like the paint melted
Sinistre1
Wow!!! There's multiples!!???:eek::dogpile:.
Has anyone determined whether it is definitively from Sun magnification/ focusing?
Joemagnum
Brandon mb
I can’t see it being from sunlight because my truck has been sheltered and maybe in direct sunlight a few days since installed
bellaireroad
Fort Worth
It looks like it is in the same spot on everybody who has it... that would point to heat from the projector I suspect
Here’s a little better photo I took. I’m not sure what the risk of fire may be, I reached out to Morimoto for their opinion
Steve Cloud
Louisiana
So, what is the company doing to remedy all of this? Covered by warranty?
Arcangel06
What good is warranty coverage if the issue is just going to reoccure?
bellaireroad
Fort Worth
I’m surprised they haven’t done testing on these to find out what the problem is. I suspect it is melting from the inside due to the heat sink being too close to the Bezel, since they all seem to be melting in the same spot
The liability could be enormous if there is ever a fire, they should be doing a recall on them
GMcD
South Carolina
$1600 dollars and thats the response you got!?! Im officially taking these off my upgrade list.
bellaireroad
Fort Worth
Well I just noticed I have signs of an early meltdown on the driver side.
It surprises me they are still selling these.
It seems the appropriate thing to do would be acknowledge the problem, find out what’s causing it and fix it before selling any more.
ChloeBrooks
