BigPhilly21Fifth
Anyone know if the 3.0L/6.2L MGU will work on a 5.7L if you move the computer that sits on top of the unit on the 5.7 to the 3.0/6.2 donor unit? 3.0/6.2L part number 68329852AE
Your avatar shows 2015, no MGU/E torque back than. What vehicle are you trying to transfer to? THAT part number shows Mopar OEM Alternator, not MGU.Anyone know if the 3.0L/6.2L MGU will work on a 5.7L if you move the computer that sits on top of the unit on the 5.7 to the 3.0/6.2 donor unit? 3.0/6.2L part number 68329852AE
6.2's are Hellcat engines. I think you mean 6.4 which is used in the heavy duty trucks / Challengers -Chargers and some JeepsAnyone know if the 3.0L/6.2L MGU will work on a 5.7L if you move the computer that sits on top of the unit on the 5.7 to the 3.0/6.2 donor unit? 3.0/6.2L part number 68329852AE
I have a 21Your avatar shows 2015, no MGU/E torque back than. What vehicle are you trying to transfer to? THAT part number shows Mopar OEM Alternator, not MGU.
The part number is listed as compatible with: RAM 2020-2024 Engines: 3.0l v6 turbo diesel engine gen 3. 6.2l supercharged hemi v8 srt engine.The MGU's have different mounting points for different engines, so not likely. Also, I think the MGU for the 3.0 is lighter duty, but not sure.
Well u may wanna change yer Avatar info.The part number is listed as compatible with: RAM 2020-2024 Engines: 3.0l v6 turbo diesel engine gen 3. 6.2l supercharged hemi v8 srt engine.
It doesn't look like it has the "computer" on top like the 5.7 does. Was wondering if that was the only difference. Different morning points would be a big difference though .
That's a mistake or misprint,as the 6.2's don't have the MGU unit,they have a belt driven supercharger on top of the engine,where a MGU would be bolted toThe part number is listed as compatible with: RAM 2020-2024 Engines: 3.0l v6 turbo diesel engine gen 3. 6.2l supercharged hemi v8 srt engine.
21 Laramie 5.7 etorqueYou say you have a 2021. Which model, trim level Is the truck E Torque equipped or straight VVT, as that missing info changes the internet guessnosis.
Yeah that makes senseThat's a mistake or misprint,as the 6.2's don't have the MGU unit,they have a belt driven supercharger on top of the engine,where a MGU would be bolted to
If he is looking for an MGU, I will venture that it is an ETotque. Trim level is irrelevant as to whether it is .Well u may wanna change yer Avatar info.
IMHO just go and buy the alternator made for the vehicle. Easy peasy.
But yer ride n wallet do as U see fit. Disregard part number I listed previous post since I went off yer Avatar info.
