Motor Oil shortage ... really? PUP 0w40 an others PUP should be OK ...
Zoe Saldana
california
6.4l
Looming motor oil shortages—particularly for low-viscosity oils (like 0W-8, 0W-16, and 0W-20) used in modern vehicles—are driven by the war in the Middle East and the closure of the Strait of Hormuz. The conflict has heavily restricted U.S. imports of Group III base oils, which account for about 45% of the supply. [1, 2, 3]
The Root of the Scarcity
  • Pearl GTL Facility: The world's largest gas-to-liquids plant, located in Qatar and responsible for producing a massive portion of the world's Group III base oil, suffered significant damage from an Iranian missile strike.
  • Supply Chain Breakdown: Because 70% or more of modern motor oil is formulated from these specific base oils, the U.S. is facing a severe squeeze, with Mideast-origin supplies practically cut off.
  • Diverted Resources: Typically, the U.S. would supplement with supply from South Korea. However, Asian refiners rely heavily on the Strait of Hormuz for crude and are prioritizing jet fuel and diesel because of their historically high profit margins. [1, 2]
What This Means For Your Car
  • Skyrocketing Prices: Supply chain constraints have led to repeated, unprecedented wholesale price hikes that are being passed directly to consumers at auto shops and dealerships.
  • Automaker Workarounds: Industry groups like the Independent Lubricant Manufacturers Association (ILMA) have noted that shortages could last up to a year. To avoid service delays, automakers like Toyota and Nissan have issued bulletins that temporarily authorize the use of slightly higher-viscosity oils.
  • What You Can Do: If you are due for a service, call your local mechanic or dealership ahead of time to confirm the availability of your car's recommended motor oil. You can also use tools like the AutoZone Store Locator or the Advance Auto Parts Store Locator to check for availability on your preferred synthetic or conventional oil quarts if you plan to top off your engine yourself.
Is there a motor oil shortage? Here's why your oil change is ...
May 20, 2026 — Holly Alfano, CEO of the Independent Lubricant Manufacturers Association, said she expects to see some motor oil shortages by early July.
Pennzoil Ultra Platinum 0W-40 is produced in the United States by Shell Lubricants. The base oil is manufactured using a patented gas-to-liquid (GTL) process that converts natural gas into crystal-clear full synthetic base oil, rather than being derived from crude o
Theoretically, there is no reason for PUP to go up in price. It should be priced by natural gas and not crude oil. It should be in supply BUT if others who need motor oil move to PUP it could be harder to find.
There oar other motor mfgs in the USA and I hope they increase their production.
I always have enough for the next oil change on hand.
Show all
AI can make mistakes, so double-check responses
jc56berg
houston, TX
Seen it too "Z" and picked up an extra jug of PUP 5W/20 this week at wal-mart. Good for two changes. I average 600 miles a month and change at 5K. Thinking of getting another jug just for grins.
Z
Zoe Saldana
california
6.4l
I think what we have now is panic buying and that cleared the shelves.
I looked on Amazon - I saw 6 PUP 0w 40 for $63 or $70. My last purchase of 6 on amazon was $43.
Now gouging.
My guess - when the war ends, panic buying ends, shelves get stocked and prices come down.
Something more crazy, Fram, Amsoil, rp and every spun glass oil filter is going away after revolutionizing oil filtration despite record customer demand. Glad I stocked up, what's the harm in buying a few 5 qrt jugs? I was able to get a few jugs but was limited in choice from outages amazon software said (June 12) expected re stock date, but sounds like I heard before. If you don't care about the oil that goes into the truck, my guess you will be fine, if you are loyal to the brands that are short, mise will buy a few jugs. PUP and all shell brands going short or change formula to hydro cracked til the crisis is over and stuff is fixed.
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
Just ordered and received 5 qt jug plus 2 qts of PUP 5w 20 so I am good. Got a Mobil 1 filter and a big RP so good there. Gotta check on Carquest and see if I can get an EP Carquest.
Might even order another 7 qts oil and another Lubeguard Bio jug for good measure
turkeybird56
Central Texas
Still lots of oil on my local Canadian Tire store shelves ;)
Locally here they do not offer PUP Ultimate only PlatinumI have to order regardless. But My oil changes are on time and not OCI ie 5000 miles. Last was done on 3200 miles but was also like 15 month period so just wanted get out old and in with the new. I put under 200 a month on truck unless I take a trip towards Austin to meet a friend fer brunch. That be a 200 mile round trip and only time truck up and over 65 mph. Since got that moisture content over months time reason fer change.
turkeybird56
Central Texas
Thank god I have about 7 or 8 gallons of rotella.
Rosella I can get PUP ULTIMATE takes some work but then I don’t have a Cummins hee hee.
MeatCurtains
US
2011 2500 tradesman, 2018 2500 tradesman, 2014 1500 Laramie
6.7 Cummins, 5.7 hemi
My other vehicles I'll just stuff whatever correct weight oil I can in them. Theres always some cheap ass oil out there somewhere.
Z
Zoe Saldana
california
6.4l
According to Honey the high was $74 or 12.33 about what you would pay at an auto parts store.
Buddy
Ottawa, Ontario - cool town
Yep, have quite a few around here, and all have lots on shelves. Of all oil brands.
What they have way less of is the Fram oil filters, specifically the Ultra Synthetic.
Actually, I had the Fram oil filter page bookmarked, was cross ref with other brand filters part #'s to see what I needed. And today... the Fram site is gone. No part numbers, no nothing. Gone. URL not found on this server.
Glad I stocked up. Between RP and Fram Ultra, I have a solid stock of filters. Also have a solid stock of PUP, Redline, and Amsoil. All the vehicles are covered.
Z
Zoe Saldana
california
6.4l
THIS IS WILD PART 2 - PRICE BACK UP to $62
Ram201963
