Mounting Hardware for Mopar Tube Steps...
DeputyDipShizz
Pennsylvania
Anyone know where just the mounting hardware can be picked up? I have the steps with 3 pads one for each door and 1 for the bed as well...Took em off and want to sell em but the hardware is rusted all to hell and would be much easier to install with new hardware...TIA
=DROID=
The Assassin
B-more careful, Murderland
=DROID=
My suggestion would be to contact the dealer. See if you can get a part number. From there, look online. Odds are, you'll find it a LOT cheaper. Idk that the bolts and anything are special, but perhaps also your local hardware store?
DeputyDipShizz
DeputyDipShizz
Pennsylvania
Called the dealership and they say they only sell the whole package and not the mounting kit seperate
=DROID=
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
Well, if you're after bolts then I would get some grade 5 bolts and call it a day.
Sent from my DROIDX using Tapatalk
DeputyDipShizz
DeputyDipShizz
Pennsylvania
It also has oval pieces of oval steel with a threaded nut in the middle...They fit into the holes by the pinch seam...seems product only kinda thing
=DROID=
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
ripped from another forum, great info here!
I think I can help you. I am attaching a picture. I think what you need is #2 for your particular design, whether it uses 2 brackets on each side, or 3. According to dodgeparts.com the 2 bracket kit costs $11.94 and the 3 bracket kit costs $25.26
ramthis9501
Oklahoma
5.2 V8
spray the existing pieces with some rust converter and paint them black, that should work
