Andrew Austin
Just curious if any of you guys noticed much difference in MPG when switching to 35” tires from the stock 33s. Thanks.
Why do I feel that’s what I have with my 275 65 20’s I get about 7 to ten.I have a 1500 with 37s and I get 14-15 in town and up to 17-18 highway .... I did regear to 4.88s and when I still had the 3.21s I was getting as low as 11 and 10 mpg in town lol .... that was one reason I regeared ...
But yes, you will notice a difference for sure ....
believe it or not the oem duratracs weigh 53lbs per a fed ex scale. I run my Toyo E rated 35's at a much lower psi and perfect wear and much better ride. Toyo has an excellent guide for setting proper psi. weigh your truck and set the psi to the right level.2019 PW, just went from original 33" Duratraks to 35" Toyo Open Country AT IIIs, E rated (very hard to find). (Duras were not safe for winter up here though they had some tread left after 37,000 miles with a lot of towing.) I have not adjusted the computer for different tire size but nearby fairly flat stretch where I used to get 19 now shows 15 - 16. About 15% different. tiresize.com says the Duratrak is 634 revolutions per mile and the ATIII is 602 revolutions per mile, that is 32revs/mile different or about 5%. Toyos weigh 72 lbs, Dura weighs 60 lbs.
The difference in driving is massive.
The Toyos track so straight I can take my hands off the wheel for a mile at a time on the straights. Duratracks always seemed to wander.
Running 55 psi in back unloaded is too high, when I pull into a dusty place the rear tires get dust onthe middle section of tread, the last inch or so on the outside and inside does not get dusty. 45 psi in front unloaded seems right, probably need same in back until loaded.
The snow performance of the AT IIIs is at least equal to the Duras, if not better. I live where the pavement is white for at least 3 months a year for the first few miles towards town, so that is very important. I have some BFG ATs on an FJ Trail Teams and some 32" Duratraks on an 04 Grand Cherokee Limited with the auto lockers, the truck is by far better at braking, turning and accelerating in snow or ice than those 2. Better braking, and cornering in the snow and ice.
Not if you change the perameters with a pro cal snap, tazer, or alpha obd.When running that low of tire pressure, doesn't the TPMS sensor light come on all the time???
