Mpg with lift and tires?
DodgeLife2500
V8 Magnum
Hey guys I'm new to the forum. I was just wanting to know what mpg you guys are getting when you lift and put tires on your truck. Can you let me know how many inch lift you have and size of your tires.
I heard that on a gasser a lift and tires kills fuel mileage compared to a diesel so I'm just curious and want to know real world numbers! Thanks!
War Machine
With 38s I average about 12 mpg which isn't too bad
GoldenOne
Central Missouri
I have a 6" lift with 37 X 13.50's and I get about 11 hwy and 8 city.
argray90
NW Burbs, IL
Your mpg will decrease I have 5.5" of lift on 35s and I get 12-13 in town and 18 at max on the highway. If your concerned about MPGs then don't lift it.
sausec17
Banned
ATLANTA
13mpg with 35's, 7.5" lift, and 3.92's
D
DodgeLife2500
V8 Magnum
well a lift and tires make the truck look sick so I definitely want to do it. I have a 99 1500 with the v8 magnum now and i get 10-11 city and 13-15 highway so I'm not too concerned I'm just curious of what i would get if I move up into a 4th gen 1500 with the hemi.
Dema
Tennessee
That's pretty good mileage for that much lift. Your truck is similar to what I'm aiming for. 2.8 bilsteins and 3" body lift.
argray90
NW Burbs, IL
I do have a tuner as well which helped me gain a one mpg or so which is nice. And you have the 4.7 as well so you'll see similar results I imagine.
Dema
Tennessee
I plan on getting an edge CTS probably before I even lift. So I can imagine I will. Any good power gains?
mcompany
Canton, OH
2011 Power Wagon
Got a 6" long arm with 37x13.5 nitto trails. I get 12 highway 8-9 city lol
slodsm
Life begins at -160f
Fort Worth Tx
2016 Laramie Crew Cab
When I had my 35's on 18's I was able to eek out 18 on the highway going to and from work hand calculated. Recently went down to a 33" tire on a really wide wheel just to change to look up and I dropped to barely topping 16 on the highway. I really have no idea what I get city because I have my boat hooked up to the truck at least 1/2 the time when I'm off work and so my mix of city/towing is low 11's.
D
DodgeLife2500
V8 Magnum
That makes sense the wider the tire more rolling resistance.
slodsm
Fort Worth Tx
Tires are the same width, I'm blaming it on these 20/12 wheels weighing a lot more than 18/9's but I like it better do oh well. I was bored with the old setup, it had a lot of miles on it.
raptor1797
Ohio
I get 13 in town and around 16 on the highwy but most of the time im in my truck I have a 7 x 16 enclosed trailer hooked to it and I only get around 10 - 11 . I miss my oil burner but not the upkeep on it !
Diller
Nashville TN
6.7 HO Cummins
Did anybody notice a significant drop in MPGs with just a level? I would like to pick up the front end a little and get some stock size Nitto Terra Grapplers but I do enough highway travel that a few MPGs does make a difference.
argray90
NW Burbs, IL
The level isn't what kills it it's the tires if you go larger and aggressive. The level might have a small decrease.
