nasty rust problem
hogslayer78
I have a 99 2500 sport 4x4 that has awful rush in the frame around the steering gear box area. What would yall recommend doing to fix this I thought of plating both side with 1/4" steel but im leary on trusting this on the road or in the mud. Thanks for your input
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Never done this on my dodge, but my old 88 Suburban had some real bad rust where the steering box mounted. So I cut off the old mount and welded new 1/4in steel plate in, then stabilized it by welding little 1.5x1.5 square 1/4 plate on each of the corners of my new mount. Thing was solid as a rock. As long as you clean the rust off where you are going to weld, and are good at welding, I see no problem.
H
hogslayer78
exactly
That is exactly what I planned on doing thanks
dapepper9
Iowa/Nebraska Border
5.9L V8
If you want it to last, sandblast everything, cut the affected area out, weld new in, por15 all that ****
H
hogslayer78
here is a pic of what im dealing with
The first pic is the outside the second pic is the inside. Thanks
sbarron
Wasilla, Alaska
likely junk. If that spot is that bad, you need to ask what you can't see, as well as other places on the frame. That's probably the worst place to have that happen too. Gonna be a serious amount of work to fix correctly. Take a good look at the rest of your frame, and see if it's worth repairing that section, swapping frames, or putting your good parts into a different truck.
H
hogslayer78
That is the only spot on the frame with any rust
sbarron
Wasilla, Alaska
If so, then it's probably worth repairing that section. Thought about splicing in a donor section rather than bandaging that one?
H
hogslayer78
donor section
Yes I have a donor section but not sure as to how far back I need to take it back because of the wheel components and all of that my donor section was cut right under the cab
sbarron
Wasilla, Alaska
Yeah, that's gonna be the $64,000 question,... hopefully not literally
The hardest part will be keeping it straight (or at least the same straightness as the existing portion). Gonna be major surgery.
joshhhh
