Navigation Guidance
1500Hoosier
Northern Colorado
Hemi 5.7 MHEV
Hey folks, new to the site (and Ram 1500 Long Horn) so I home I'm not asking a question that has been asked a bunch of times.
I set the volume for navigation guidance in the navigation menu. When I turn the truck off and restart it defaults back to level 15 which is very loud. I know all I have to do is turn the volume up when I'm getting voice guidance but how do I set the default volume to something less than 15?
Thanks much,
Jim
dhay13
Hope someone knows a fix for this but I think it is default. Mine does it too and it is very annoying
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
This may not help, but both my 2009 & 2016 Ram 1500s, had a setting in the radios Menu, i found a setting that let me separate the different volumes.
Hopefully you are able to do the same with the newer models
Randy Grant
KITTITAS, WA 98934
I turned the guidance off in mine. It just irritates me. The DIC has a popup when a turn is getting close, so I don't need another whiney woman telling me which way to go.
Justthebutler
BC
2017 Ram 1500 SLT
You may be able to do it in alfaobd I know you can disable navigation lockout so you can use it while driving, it may prevent it from changing the volume?
mikepol2
Pittsburgh, PA
Same here, it’s infuriating. Does the same with my iPhone, had to unpair it so I wouldn’t have a heart attack every time someone called while I was driving. Took it to the dealer and had a brand new radio installed and software updated but no difference. Has to be something with the Uconnect software. I actually was messaged months ago by a Ram rep who said they heard it might be addressed in a future version of the software but then they never did issue an update (I check regularly). Can’t wait till I can ditch this thing and it’s creaky sway bar end links and get back into a Silverado. Drove them for 20 years and thought I should try a Ram and now I’m regretting it.
RJR49
Marine Corps
Thanks much,
Jim
There is a setting on u connect to save the last radio / entertainment setting. That should do it
Daw14
South Florida
Dealers are open right now !
mikepol2
Pittsburgh, PA
Yep the dealer tried that on both the old and new radios but no luck. Tried the nav-specific settings with the nav-only volume but same thing, adjusted to start at 2 but once you restart the truck it’s back at 15.
Dean2
Near Edmonton
Where in Alpha did you find the toggle to disable the navigation lock out while driving? Thanks.
On my 2500 I can adjust the nav volume with the radio volume control while the nav is talking. In mine it seems to hold that setting even after shut down and restart. You may want to check and see if you can adjust the volume the same way, but the nav has to be speaking for it to work.
Justthebutler
BC
2017 Ram 1500 SLT
Where in Alpha did you find the toggle to disable the navigation log out? Thanks. On my 2500 I can adjust the nav volume with the radio volume control while the nav is talking. In mine it seems to hold that setting even after shut doewn and restart.
When I get home later I'll have to check on my laptop and send it to you , I think the guys narrowed it down to certain years; But I cant remember.
