Need a little help on rake
Ferro
I'm new to the forum and been browsing for a long time. I find this forum very helpful. Here's my first question on this forum...
I have 2016 1500 sport with a zone suspension lift with 35's & I love the ride of the truck. Also love the stance. My question is how do I raise the front end up a inch & a half to level it out? What are my options? Thanks in advance.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
2WD or 4x4?
If 4x4, Bilsteins will give you the lift your looking for.
If 2WD, check out CST or Maxtrac.
F
Ferro
It's a 4x4 I was told the Bilsteins aren't meant to get the rake out of my truck. Seeing that it's a 4" lift. I'm kind of doubting what I was told. But I thought the Bilsteins were for stock suspension if you want to level it out. I'm confused.
Juvenator93
You can run Bilsteins with a lift that uses a spacer on top of the strut. I had a 4" with Bilsteins set to 1.4 and had 1/2" of rake
F
Ferro
Thanks guys I wasn't sure I could use Bilsteins with the spacer on the strut. I'm assuming I set the Bilsteins to 1.4 to get a 2"lift in the front.
Jerred17
