Need ACC or Ignition signal
SeaSickSailor
Hillsboro, Or
6.4L Hemi
I need to find a fuse in my 2019 Power Wagon that has a signal on it when truck ignition is on either ACC or RUN. It’s for operation of my Switch-Pros system. I can’t use fuse 90/91 as that is in the battery position to enable my solar charger to charge my aux battery. Either a fuse that I can fuse-tap or a convenient wire that I can tap. Any ideas? Thanks.
Brandon-w
Yukon
2015 Ram 1500
Blower motor resistor plug?
Sent from my SM-A530W using Tapatalk
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Uhhh, I don’t even know what blower motor you are talking about. Sorry, I guess I need more smarts on these engines and supporting systems. Can you please shed a bit more light on this? Thanks.
Brandon-w
Yukon
2015 Ram 1500
this shows where it is.
turkeybird56
Central Texas
Have U gotten around to the 2019 DT trucks yet with the 48-11 BW (auto) yet? I just put new shoes on mine so I know I am good to go, Just curiosity... U had said something abouot looking at 2019, wonder if the New 2019 DT 's with the "new" systems.
Brandon-w
Yukon
2015 Ram 1500
Have sent a harness to a member for testing. It's being sent back for some refining. Things are in the works hopefully I can get it figured out and into production.
turkeybird56
Central Texas
I do know that FCA changed some of the maps on the operation of the 48-11 to "improve" it... LOL... But with my new shoes (Falken ATW3s), hopefully be all good, even though I restrict my 4 X 4 to things like getting hay and trailer hossies. Thanks for the effort and stuff U do to help folks, especially the PPL with the 44-44 systems, which I had on MY 2015.
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Are you sure that we are talking about the same truck? Mine doesn’t look anything like what that video does. No blower to be found anywhere nor connectors as shown.
Brandon-w
Yukon
2015 Ram 1500
Ah crap didn't realize it was a 2019. Sorry man, do you have the full center concole? Could probly tap power from the back of the aux jack in the back if you do and it's hooked to key on.
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
That’s the jack I want to use on battery so no go there. And yes, I do have the full central stack with 12” screen.
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
So, no ideas floating around in here about where I can tap into an ACC or ignition signal on a 5th gen power wagon (other than fuse 90/91)? I believe I posted this query in the 5th gen audio and electronics forum. Please correct me if I’m wrong. Thanks.
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Ok. So no help on what fuse to tap. How about a wire or connector block somewhere that I can tap. I know someone out there has come upon this problem before. Thanks.
busa2009
Acworth,GA
not for sure but f66 its rather easy to find using multimeter and then use a fuse piggy back
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Don’t think that will do it. The bottom block of the attached pic lists what f66 (10amp) fuse is for. Maybe I’m wrong. 99D551CC-656E-431B-BD21-4ACA184B87A8.png99D551CC-656E-431B-BD21-4ACA184B87A8.png
Brandon-w
Yukon
2015 Ram 1500
Where is your switch bank going to be? If it's on the roof like some I know you can easily tap power off the mirrior like I've done to power my radar detector.
SeaSickSailor
SeaSickSailor
Hillsboro, Or
6.4L Hemi
Thanks. I’ll check it out.
DRam2019
Connecticut
Your truck should have come with a plastic bag with a bunch of wires in it for upfitter switches. In that bag there is a plug with wires coming off of it, purple/yellow a looped wire pink/white and looped wire red. The pink/white is powered ignition on maybe also acc on.
DRam2019
Connecticut
Forgot to mention that the plug I am referring to plugs in up by e brake foot pedal. Sort of up and behind it.
