Nealuss
- Mar 8, 2016
- 137
- 33
- 1994
- 5.2L 318
I need some help and advice from some of you small block mopar veterans out there. The 318 in my truck is burning oil and it seems to be bad rings as far as I can tell. For the time being I am just going to use thicker oil and maybe test some additives but I am going to be piecing together the parts I need to rebuild the engine over the next few months or so as well. I know I want to do a mild cam, but something I can still drive everyday if I choose to. I know I need to change the lifters and upgrade the springs and rockers at the same time. When it comes time to build the motor I plan to pull the motor, strip it down, and take it to a machine shop to be cleaned and tested so I can buy the rebuild kit. What I don't know is what cam, lifters, springs, and rockers to I need to be looking at? I have no idea how to look at lift/duration numbers and make sense of it. I know what the numbers mean but I don't know how to relate that to outcome.
Also, what can I do about tuning for a 94? I read somewhere that you can use a Mopar PCM with a Jet stage 2 chip on it and get pretty good results. Can anyone back that up or provide some insight on how I can get the motor running right without going carbureted?
Sorry for the long post but I like being thorough!
