Need Header Help
HillbillyStyle
WV
I have a 2016 RAM 2500 4x4 with the 5.7
I need to replace these junk exhaust manifolds but I'm trying to find a set of headers that will bolt right up where the stock manifolds do now. I don't want to do any modifications just a simple swap. Are there any 2500 owners here that can tell me what they used so i can order the right header for the simple swap? Thanks for the help.
Pull Ya
Cedar Creek, Tx
Check with Matt at Moe's Performance, a preferred vendor on this forum. He will be able to tell you which headers will be a the best fit.
Jay
Selcher
Canada
Hemi 5.7 eTorque
Jay
Agreed... if you can get a response! lol
Pull Ya
Cedar Creek, Tx
^^The times I have spent with him, his phone never stops ringing---He tries to get to every call he can
Jay
H
HillbillyStyle
WV
Bought a set of JBA Shortys from jegs that says they're for my 2500 but the passenger side hits the frame. Would need to remove about 3/4 of an inch from the one pipe just to get the header installed. Pretty upset at the moment. Mechanic is having to put my old manifolds back on and I'm stuck with several days of labor cost without accomplishing anything to prevent the bolts from breaking again.
Sent from my SM-G955U1 using Tapatalk
Pull Ya
Cedar Creek, Tx
See post #2.
Jay
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
If it didn't have these numbers 1961S-***
It's not for the 2500
Matt would have sent the correct ones.
crackerjack1957
Someone else had this issue on a 2500
https://www.ramforum.com/posts/1810997/
