Need heater help!
FancyStancy
Cummins 6.7
I have a 2008 Ram Laramie Megacab and am having problems with the heater. The truck only blows luke-warm air at full operating temp. I topped off the coolant on the truck with no results. The 2 passenger vents blow noticeably colder air (when at full heat) than the 2 driver side. Any ideas?
Trenton
is the coolant up in the rad or did you just add to the bottle? if its up in the rad with engine running feel the heater hoses one should be hotter than the other but both should be very warm. If one is a lot colder your core may be plugged do you change coolant regularly? If both are hot you may have the blend door problem and will need to repair it.
FancyStancy
FancyStancy
Cummins 6.7
Yes coolant is in the radiator. I will check the hoses as soon as possible though
FancyStancy
FancyStancy
Cummins 6.7
Also want to mention truck only has 65k miles. Is a flush something needed at this low of miles?
crcraft
