Need Help! Electrical Problems
jeff_z
5.9 magnum
Hey, I've got a 97 2500 5.9 gaser. Been having a lot of electrical problems. When I turn my lights on all of my gauges act funny (speedometer jumps, rpms jump, temp gauge goes up, etc.) Also without the lights on the gauges will do the same when the a/c is turned on. Anyone else have similar issues.
Thanks.
esiegel91
Waddell AZ
360 v8
Sounds like a short in a wire or two wires maybe broken and touching? Check under the dash and see if you can't spot something..if you can't, it's time to break out the multimeter
