I'm putting in a Painless Fuse Block (has relay, 3 constant and 4 switched)
under the dash.
I plan on pulling the relay switched power from the brake light pedal wiring. It's 3 amp.
Positive will run back through the firewall to the the battery. It comes with an inline fuse.
For all of you "hobbyist" out there.... I know I could have put this together from scratch, cheaper, but considering the cost of wiring and >>>> time, this is a great value to just "get-er done!"
All I have to do now is fabricate a simple metal bracket for mounting/ground. I like cutting and drilling
I am very satisfied with the quality of assembly/workmanship and all of the wires are ----> labeled as well as have more than sufficient length. It actually was more/better than I expected. This will make wiring up my Dash Cam, CB, other in-cab stuff.................... easier.
