Need help
wndwlkr2
Austinburg Ohio
I have a 2006 quad cab 4x4 with a 5.7 it overheated and is toast I found a 2014 5.7 392hp comes with ECM and wiring , can I make this swap has the blocks changed ,I need to bolt to my current auto transmission
HemiLonestar
Navy Badge Coast Guard
MD
Will bolt to your transmission. Will not be plug and play. 09+ has variable valve timing and an active intake manifold.
jotin
your mom
Also the newer engine have a smaller tooth tone wheel for the crank sensor. 08 and older has a 30 something tooth. Newers have a 50 something tooth. It won't run
