Need some cam info
Michael.Banks
Banned
I have been looking for a cam for my hemi ram and have a question. A buddy of mine said that the least expensive route would be to get a 6.1 reground. The question I have is with the wide lsa of 6.1 cams, will I have enough low end to get my quad cab moving? Any input is appreciated
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
a lot of guys have done exactly this. the low end torque loss isnt really all that bad from what i hear. and you can easily combat that with a set of gears.
M
Michael.Banks
Banned
That is the problem, I don't have the funds for gears. I want to make sure that I will still have power with the cam without having to do additional mods. So I am thinking that without gears a 6.1 regrind won't have the guts down low that I need to get the truck moving.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Get a Comp 260, Interia Crazy Jay, Crazy Spartan or find a used Sidewinder. I had a 6.1 regrind and your the same either way. Say you pick up a used stock 6.1 then you shell out 250 for the crower regrind then you need custom cut push rods at 200 I think. What do you have far as a tuner at the moment?
M
Michael.Banks
Banned
I am running a superchip. Not really looking for a custom tune which is another reason I am looking at the 6.1 regrind. Heard that they run fine on superchip. Do you know anyone with a 6.1 regrind in a heavy truck like a qc 4x4? I would like to hear their feedback.
truckin151
2013 sport
Rubberfrog has a 6.1 regrind in his truck I believe but all the cams llisted above will run on a sc tune (or at least should run on an sc tune). Once you get into the bigger cams then you need a tune.
M
Michael.Banks
Banned
I am not familiar with his truck. Is it a heavier truck? Does he have good low end power?
truckin151
2013 sport
Yeah his is a big truck. Hopefully he will chime in here soon.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I think George said something to me about doing some family stuff today - he might not be on to reply.
Basically, George has a 6.1 reground cam in this big old beast:
It'll smoke 35s too, while passing emissions! :D
M
Michael.Banks
Banned
Can he smoke them by just stomping it or does he need to powerbrake it? What version lsa of the 6.1 does he have bc I heard there are two different 6.1's.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
no brakes, and I have no clue. :D
M
Michael.Banks
Banned
Ok, well thanks for the info. Maybe if you talk to him you can ask him to post up a video if he has it. An some info about his lsa. Thanks.
truckin151
2013 sport
I believe you cannot change the lsa on a regrind so it will be bout what the stock 6.1 lsa is (114-116) which is very pcm friendly.
M
Michael.Banks
Banned
Well I ask about the lsa bc I read there is a 115 and a 117 version.
M
Michael.Banks
Banned
Here is his truck
[yt]vsqkZyFO8t0[/yt]
After watching that it looks like he is on the brakes. The truck noses down when he hits the gas. I guess a 6.1 isn't what I am looking for bc I want something that will really smoke them and something that will spin them without brakes.
Will any of the other suggested cams give me more power than that 6.1 will?
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
frog's grind is about the most power you're gonna get out of a superchips friendly cam. If you want to smoke the tires from a get-go, get a bigger cam and a custom tune and/or gears.
RubberFrog
There's no brakes in that. I just lift off the brakes and stab the gas. Obviously I had perfect weather, I can't do that quite so well in the summer time.
As mentioned previously, you can't get much more aggressive on a canned tune. My grind is a little more aggressive than a sidewinder/260 and is not mds friendly. If you like your mds, stick with a milder cam.
I don't know what you're running for tires, but I would love to see what I could do on a set of 32s without the shell.
I have a 115* lsa with a 4* advance.
M
Michael.Banks
Banned
There has to be some brakes in that. The rear wheels start turning and then nose of the truck dips before going forward. Still nice video but not a stomp and go.
gville35
