Need some Engine advice
Mack
South Carolina
4.7 Magnum
Should I look into getting headers? Hiflow cat? throttle body spacer? Put new gears in? Should I chip it? any cheap chips for small boost? Just wanting more horsepower/torque, get-up-and go type of deal. Got this truck about 3 months ago and its been my love ever since.
Mack
Mack
South Carolina
4.7 Magnum
If I get better gears, would I have to change out anything? transmission? drive shaft?
usaf2006
North Carolina
Just gears..both if its 4wd. Take it to someone qualified though. Check out moes performance(vendor on here) for gears, tuner and such. Good prices amazing service.dont get a tb spacer. Junk. You can do a cat delete... very high flow ;) lol it all depends on your budget.
Where in SC are you? Im right on the border in Augusta.
Mack
Mack
South Carolina
4.7 Magnum
How do you do a cat delete? make my engine light come on?
And im in Greenville sc, cherrydale area. were can I get a hi flow cat
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Moes for your parts. you can do non foulers w/ 0000 steel wood or have a custom tune done (the latter means getting a programmer that does custom tunes = more modding $$)
Mack
Mack
South Carolina
4.7 Magnum
What is non foulers ? and programmers cant make it sound better can it? but I would like lil more horsies
Mack
Mack
South Carolina
4.7 Magnum
I found it on a 04 ram, pretty much tells the 02 that the cat is still on, but would gas milage be effected?
usaf2006
North Carolina
What I've heard it's some guys claim better mpg. But in reality it really isn't affected much. Hey pumpkin where does the steel wool go? I've watched videos and read but only have heard it mentioned but not explained what the steel is for.
usaf2006
North Carolina
Free flowing. I would assume itd have noise addition but with the resonators and muffler you.probably wont notice.
Mack
Mack
South Carolina
4.7 Magnum
I have the flowmaster 40, dual out. and no resonators. But got my cat off and did the non fouler trick, I had to cut into the heat shield to make it fit, but I threw a code, added another fouler, code went away. 100 miles still good. Sounds great.
geneseedennis
