Need some help
Mopar89rc
Fresno
hi I have an 89 ramcharger and I’m going to lift it but not sure what to do it has 3 1/2 blocks in the rear which as far as I know are stock and I’m wanting to do a four inch lift but if I do that wouldn only give me half inch more may may be a dumb ? But I need some help and any of it would be appreciated
crazzywolfie
under the truck
just buy taller lift springs for the rear so you can remove the blocks. there is still a chance you may need something similar to a ladder bar setup to prevent axle wrap but you are more likely to have axle wrap if you lift it and keep the blocks.
joshhhh
