Need to match Subs to amp
BadHabit2Break
Houston, Tx
3.6L
As far as sub size, that depends on what you want and how much room you have for the box.
That amp has an RMS of 1200 watts at 2ohm. So running either two subs that are 4ohm each or running one sub that is two ohm. You want something that can handle 1200 watts RMS.
Sonic Electronics is a good site, you can filter out from the list what your looking for in a sub.
adurm
FL
2015 RCSB
Sundown makes good subs in my opinion.
countrygunner
You coil use either 2 dual 2 ohm voice coil subs or two single 4 ohm voice coil subs. Or one single 2 ohm sub.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
The KX12001 will do 1 ohm, if OVP taken out can do 16v and down to .25 ohm...dis I know :)
Get two DVC 4's, wire for a 1 ohm load.
bamagrad03
Take a look at Image Dynamics IDQ series. They do well in smaller air spaces and run in 4 or 2ohm DVC.
