Needing Wheel Help
Rosser
Vestal, NY
This is my first time buying wheels for a truck and need some help. I have a 2016 2500 Tradesman with 18” wheels. I did do the 2.5” front leveling. I’m looking at 18” Helo HE879 with 5.71 backspace and -12mm offset. I want to run 35” tires and want to know will I rub and how far could my wheels stick out the fenders?
BOWERSFJ
Uniontown OH
How wide a tire are you wanting to run ?
R
Rosser
Vestal, NY
So I need to update my post the wheels are -12 mm, sorry
Will a -12mm make a tire rub and have to much wheel hangout from the fenders?
1500ram12
5.9L Cummins
You'll be fine. Here's mine with -18 and 35's. 2" RCX Level No rubbing whatsoever.
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
Fishstickz
Oklahoma
'06, '16
3.7, 5.7 Hemi
I’m running 33x12.50s on a 1.5” level with no rubbing on my ‘06. -25 offset and 4.5” backspacing. My truck is very different tho
Give custom offsets a look. Theres a lot of trucks posted up and you can see their specs and how much rubbing they ended up with. Looks like a few are running 35x12.50s without rubbing in the -19 to -25 offset range. -12 is pretty close but you might get lucky lol
