New Lift kit ? what to choose ?
klind
Ram 1500 4x4 Crew 2014
I am looking for a lift kit, maybe even just a leveling kit.
I would like to have some 325/60R20 Nitto Terra Grabler
With that said it doesn't have to be those, could also be something that is around 34"
The 325/60R20 Nitto Terra Grabler are 35.12 according to this
Terra Grappler - All-Terrain Light Truck Radial
So I have been looking at
2.5in Leveling Lift Kit for 12-14 Dodge 4wd 1500 Ram [358] | Rough Country Suspension Systems
as a cheaper solution ( I am not doing any crazy off roading anyway )
or one of the these 4" kits...
4in Suspension Lift Kit for 12-14 Dodge 4wd 1500 Ram [323S] | Rough Country Suspension Systems
Rancho Suspension: Suspension » 2013 - 2014 Dodge Ram 1500 Suspension Systems, Lift Kits, Leveling Systems & Shocks
Anyone have an opinion ? And I know a 6" almost cost the same at a 4", but I do not need a 6".
Thanks
tsunamilogan05
Gainesville, GA
Don't level because after new ucas to ensure your ball joints don't pop out you'll be paying close to a 4" kit. I was going to level until this problem started popping up. Might as well go for the 4 or 6
Sent from my SAMSUNG-SM-N900A using Tapatalk
xrsman
Ontario
3.0 Ecodiesel
I think for running that size of tire you would want to use the 4" lift. I have that same 2.5" level on my 2011 and the stocks look fine on it. Actually I didn't even put the rear spacers in because it was perfectly level without them. IMO 35's would look a bit big with just the 2.5" but would be perfect with the 4". Here's a pic of mine with the 2.5" levelView attachment 26292
K
klind
Did you have any problems with your ball joints ?
K
klind
How much are these UCAS ( I have no idea what UCAS are ) :)
And are they necessary ?
xrsman
Ontario
3.0 Ecodiesel
No I've never had an issue. (Knock on wood! Lol) The lift has been on for about 30,000 kms so far
tsunamilogan05
Gainesville, GA
The uca (upper control arms) have been only an issue with 2013+ rams. Anything over an inch will possibly cause the ball joints to pop out.
tsunamilogan05
Gainesville, GA
So even with the most affordable off road UCA's (zone offroad) your still looking at about 1k give or take to level your truck. Might as well lift it for a few hundred more.
LovedMy 2500
