New Member Diagnosed O.C.D.
used2bfast
Hurst Texas
As the title states.
Have a 2009 Ram that the previous owner did a lot of work to. I have done little odds and ends to it. Just received my custom badges from Billet Badges. Will not get em installed for few weeks.....
I am trying to get it somewhat double duty. Show and work truck... Currently have a Coachman bumper pull that weighs in around 6.5k pounds. Added air springs to rear...
Day I brought her home
Custom paint from P.O.
Got a set of 17's and had them powdercoated almost like Rhino lining. Made for a better ride.. Also, I volunteer with the local Skywarn, so i needed wheels that would not be hard to replace if damaged.
And yes, she has won best in class. (once) :disgust:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I know that truck! dude bought a chally.......
Doc Fluty I think was the guy's forum name.
Welcome to RF!
used2bfast
used2bfast
Hurst Texas
Yea, I am thinking he did not work her too hard.. Tried to see if he had any pics of the truck " working".. (was going to add picture to the ones I take to shows).. Guess he did not have any...
Kind of hard to keep things in line when using it as a truck... But, its all good..
LB3711
Trumbull, CT
3.6L V6
Welcome
Sent from my tapatalk equipped AT&T iPhone 4.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Welcome. Yeah that was Docs always loved the pinstriping on it.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Welcome to RF....
I don't know what's harder...tying to maintain a DD (dual duty) ride...
or having everyone remember it was somebody elses ride all the time.
Time to work on makling it your own. Here's to that! :birgits_tiredcoffee
TLC John
2006 RAM 1500
Hi Used2B....If you haul or tow heavy loads....
Hi Used2B,
Welcome to RF! Enjoy your new (to you) RAM! Really like those wheels!
There are a lot of great people and tons of info here.
Since you mentioned work truck, please take a look at the new Total Load Control™ Air Suspension Systems.
TLC's patented system solves the RAM 1500 coil spring problem – smooth everyday ride that can’t handle heavy loads. TLC adds 5,000+ pounds of lift so your truck will always be level - and TLC improves steering, handling and braking too.
TLC™ is a revolutionary patented air suspension that uses 9" Goodyear air springs - the largest on any full-size truck. TLC’s air springs operate independent of the factory suspension so they don’t interfere with the smooth factory ride. In fact, TLC can give your truck a “sportier” feel.
TLC's air springs have at least 5 times the power of "air springs" inside the coils. TLC levels heavy loads with only 20-30 psi so the air springs remain flexible compared to others that require 80-100 psi.
TLC also has a new model, DGHD-2535, for RAM 2500 and 3500 trucks (2002-2012). This unit is super tough with 1/4" steel platforms that will level the heaviest loads, trailers and boats. TLC's 9" air springs have at least 3 times the air volume of systems that use 6” air springs.
All TLC models are easy to install; fit single or dual exhaust and require no modifications. You can order with or without a Viair air compressor and gauge/switch.
Of course, TLC cannot increase GVWR or GCWR so please do NOT EXCEED the manufacturer's recommendations.
Our customers tell us - until you try TLC, you've never experienced the full power of air bags or had Total Load Control.
Shipping for the 1500 unit is free in the continental US, $40 to Canada, and $100 internationally (We ship US Post Office Priority Mail or UPS Ground). Shipping for the DGHD-2535 depends on your location as it’s a heavier unit.
We have a limited-time coupon good for $50 off any TLC purchase until June 15. Please use checkout code: RAM50OFF.
used2bfast
used2bfast
Hurst Texas
You have that Right.... It will be slow process.
Thanks John, I will look into those. I have Assist bags on it now and am not sure I like the design... Yours looks better than what I purchased. :Wedgie:
I need to figure out a vibration before any other mods are done.
ramhunter9
P-Star Jeep Wrangler
Welcome , truck looks might nice like it always has
