New member in need of some advice:favorites13:
Nealuss
5.2L 318
First off a little intro and background.
I recently acquired a 1994 1500 2WD 5.2 auto as a project. My brother bought the truck about 4-5 years ago just to have a truck if he ever needed one. Well last year he decided to go out and buy a 2014 Ram 2500 4WD Laramie Cummins and no longer needed the puny little 20+ year old 1500. I saw some potential in the old gal and decided to buy it off of him for cheap. Only problem is the truck has nearly 300k on the clock. It is in surprisingly good shape given the mileage, but definitely needs some TLC.
First thing to fix is the steering. When my brother got the truck it was barely driveable. In fact it was scary to have over 20mph. I replaced the pitman arm on it and it was at least driveable which was fine since it only went to the trash dump once a month. Fast forward a couple of years and now it is in my possession and I decide to fix the sloppy steering once and for all. I have replaced inner and outer tie rods, idler arm, remanufactured gearbox, and installed the rock solid steering fix (bushing that replaces spring and bearing on the column) and still have about 2 inches of play in the steering. The steering feels MUCH better than it did before and every little thing has helped but it still just doesn't feel quite right. I checked the intermediate shaft for play and there is none surprisingly. I adjusted the new gearbox about 1/4 turn and it got a little better but I am hesitant to adjust it anymore since it is supposed to be good out of the box.
Also for the record I have new upper and lower control arms and new wheel bearings on the way, though I have never seen ball joints affect steering like this.
TL;DR - Replaced all steering linkage and gearbox but still have play in steering.
What should I do? Have you guys ever had to adjust a reman gearbox as soon as you put it on?
Joe w.
Virginia
318 5.2l
Not sure about the gearbox but the track bar on this trucks are weak. Have you checked it for slack it will affect your steering.
N
Nealuss
5.2L 318
My truck is 2WD so no track bar. :(
Joe w.
Virginia
318 5.2l
Duh my bad missed that when I read your post. I think there is a thread on here about steering problems
N
Nealuss
5.2L 318
It's all good, thanks for the reply anyway! I will keep digging and keep replacing worn out parts I guess. Hopefully someone else can chime in.
N
Nealuss
5.2L 318
Anyone else have any input? Could the bearing preload adjustment be off on a new remanufactured box?
Johnn123
Ontario
Your problem is the remanned box. They are simply old boxes with new seals nothing else changed. Redhead or borgeson are the way to go.
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
i have a 94 5.2 2wd as well the thing with my truck is my steering is meh it has some play but not a whole lot.
N
Nealuss
5.2L 318
I thought that might be the case. I was trying to save a few bucks but I guess not. I might as well try the bearing adjustment and see if it does anything.
Also I just looked at the price of this steering boxes :jawdrop::jawdrop:
Agcat
