Power Steering gearbox
jimg67
Indianapolis
5.9L Cummins
Hello, I have a 2006 Ram 2500 5.9 and need to replace my power steering gearbox. What brand do you guys recommend? I see mixed reviews on the Redhead and Bluetop brands. My truck is a daily driver, and I mostly pull a boat. Not much HD off-road. Thanks!
Dean2
Near Edmonton
The gear box is rebuildable. Depending on what the issue is, I would go that route as it is a lot less expensive. If you just have play, have you adjusted the worm screw to remove the play? Also, if you have excess play, have you checked the intermediate shaft, it is often a problem on hte earlier models.
Carbary
