New Oil Filter
Joseph Godvin
Dundee, Michigan
Hello group, This is my first posting, Been trying to locate a longer oil filter to work on my 2016 Ram, found a wix WL10255 extended performance filter. wasn't sure if I had enough space to fit in in. same diameter as stock but 2" longer. worked just fine with plenty of room !! I am a retired HD Deisel mechanic ( 50 years ) Been using Wix filters for as long. We always had filter spec. books at the shop, we used them to locate other filters to accomodate more capacity for our equipment, I used this to find this filter. and as always add Motor/Kote to Oil.
Burla
2010 Hemi Reg Cab 4x4
Chlorine content of some additives...
Engine Treatment Product - Chlorine, ppm (%)
Dura Lube Engine Treatment Booster - 55,000 (5.5)
Motorkote Hyper Lubricant/Engine Treatment - 272,000 (27.2)
Motorkote MK Million Mile Formula - 207,000 (20.7)
Prolong Engine Treatment - 304,000 (30.4)
The only wix that is spunmicroglass is wix xp, I invite you to check out the oil filter thread and specifically the lab tested wix xp page 93.
