New owner. Jack points?
CaseyJones88
Canada
Hi there. Just bought a 2011 5.7. Wondering a few things. I need to change front struts and a ball joint. Where’s the best position on this truck to jack up and let suspension sag. I’ve seen people jack up from the cross member and rest stands there.
I also watched a video of a fella who replaced his struts with one tire still on the ground. One side at a time. That’s possible? I guess I’m used to solid axles where to articulate one side the other side needs to be free.
My drive way is a bit sloped so I’d prefer to only do one side at a time.
And in regards to that bottom shock bolt. Wouldn’t it be easiest to remove when everything else is still bolted down? Maybe even with the weight of the vehicle still on ground.
Thanks, glad to own a Ram
quietpeen
2021 TRX
Hellcat
welcome, and yes you can change the struts with one wheel on the ground
C
CaseyJones88
Canada
Also I’ve read everywhere the lugs are 22. None of my 22s fit. They’re 7/8? Lol. Why is everyone saying 22
C
CaseyJones88
Canada
And jack up from waaay behind tire basically in the middle of the truck? It flattened out almost at the transmission cross member.
I jacked just infront of the cross member and put one stand on front cross member and one behind the transmission crossmember.
C
CaseyJones88
Canada
Also I can’t turn the truck off while it’s in neutral? This is normal for these trucks?
quietpeen
2021 TRX
Hellcat
I have just jacked from the front and put a jack stand under the cross member.
Yes its normal to not be able to turn the truck of in neutral, it has to be in park.
quietpeen
2021 TRX
Hellcat
when you say don't fit do you mean that the 22mm is too small? I have 22 mm socket and I found it fits better than a 7/8" socket.
ram1500rsm
Trabuco Canyon, CA
Is it ideal go jack up from frame behind front tire? And put jack stand on cross member.
You can jack from the the center of the cross member and put the stands on both sides of the cross member if you wanted to lift both wheels in the air. My driveway is also at an angle so i i'll use 2 more jack stands for extra safety that i place on the frame behind the front wheels.
You could also jack from behind the front tire from the frame.
This is how i do it with one tire on the ground for example:
32621867548_9b737c4d68_h.jpg2018-12-27_07-46-18 by RAM RSM, on Flickr
ram1500rsm
Trabuco Canyon, CA
?? it may be for your year yes so what's the problem ? i can turn it off in Neutral, and also backup with the driver door opened :)
How does it help to change your struts i have no idea, lol.
C
CaseyJones88
Canada
Awesome thank you. This is what I ended up doing yesterday
C
CaseyJones88
Canada
I just have always worked on vehicles in neutral
C
CaseyJones88
Canada
So I took off my side steps because one was dented. My dad was doing the other side and he let it drop onto the ebrake cable. To me it looks like it’s sagging now. But I don’t remember it’s previous position. It’s hanging just barely below the frame at its lowest point
If this isn’t normal can and how do I adjust at the adjuster below the cab? Or do I need to pop the back breaks open and adjust with the spinner
