amenges
I recently installed the JET 180 T Stat. I installed in with needle valve up, just like oem. After installation i warmed up truck to make sure there are no leaks and everything was ok. After driving yesterday I first noticed something. The thermostat gauge goes all the way to the middle (where it normally was with the oem t stat) and then cools down to the normal spot (about the first 1/4 of the gauge)
Well I figured that was normal so didn't pay any attention to it. Then after driving around 30 miles and sitting at a red light my check gauges alarm was dinging. I look down to see my thermostat almost buried on the hot side. I panic, pull over and put it in park, and then gauge quickly goes back down to the first 1/4 again.
Anyone had this problem? Could it be caused by the needle in the thermostat "sticking"?
