New tires and alignment issue
MegaHertz
NE
I had this same issue when I got all new tires at Firestone a couple years back. Alignment was fine but my seat would shake like a massage chair at highway speed. I took it back twice to have the tires re-balanced only to wind up with the same problem. The shop even advertises their Hunter Road Force Balance system.
They finally told me that it's too hard to balance large tires or I had a bent wheel--which is weird, because it wasn't shaking like that before I got my tires replaced there. Then I took my truck to Discount Tire and they got it right on the first try. Don’t know if they have better system or better techs.
JJEH
Central Texas
Any updates? I'm just seeing this...
This is so frustrating, I know. It took me 14yrs, six franchise dealerships and several independent shops to find a good place. It's just as bad as finding a good doctor.
If the shop doesn't complete the work, doesn't inform you about it but charges you for it, they are a fraud! You should report them to all the places you can.... local news, BBB, if they are a franchisee then you should contact the franchisor, etc. Perhaps even your local DA is interested as well. I'm sick and tired of these kinds of people!
When it comes to tires, I trust Discount Tire here. They have the best prices, replacement certificates with no questions asked, and pretty quick appointments. The one thing they don't do - for whatever reason - is alignments. Good luck and don't let them get away with it.
MegaHertz
NE
I'm having this same problem now, too. Just got some new 35s installed at local Discount Tire and decided to get an alignment while they were at it. Started driving home and the steering wheel was off center--would drift to the left when holding center--and pulling to right when I let go of the wheel. I took it back twice to have the tires re-balanced and alignment checked. Still had the same problem when I picked it up. After the second time the shop blamed it on a seized tie rod. So, I took it home soaked it in PB Blaster and heated it up with a torch. Finally broke it free and took it back to get adjusted. They still couldn't get it right on the third try. So now I'm looking for an alignment specialist here in town.
