New to this forum (Transmission Service)
jes0wzy
Stuart Florida
Please HELP! I have a 2018 1500 "Big Horn" with a 8 speed HP70 transmission. I bought a pan/fluid kit from "Blauparts." The kit came with six quarts of Ravenol 8HP Fluid. After the swap I drove the truck about 5 miles no issues. Last night after about 15 miles it started to have hard shifts from 2-1. I used about 5 and 1/2 quarts to refill. I called this morning to the parts department at the local Dodge dealer and give him my vin number, he said the transmission held 8.7 quarts? I followed to "Green" paper fill procedure, however not sure I leveled it correctly ( I put a level on the bottom of the frame). I did not put a level on the actual transmission, could I have not added enough fluid or too much to cause this issue? Was thinking of just redraining and replacing with new fluid. I see a lot of talk about OE Mopar fluid verse Valvoline Max-life, has anyone used Ravenol before??? Any suggestion/advice would be greatly appreciated.
CanuckRam1313
Ontario Canada
2023 Warlock
Whole I'm no expert on the prowess of all transmission fluids.
I do know that one ONLY wants to use either the OEM MOPAR or the Valvoline MaxLife transmission fluids in the 8spd transmission.
The back end needs to be lifted so the "transmission" is level ;)
Levelling the frame doesn't do you much good,as the transmission is still sitting downhill. I don't have any experience with the Ravenol fluid,but if it's shifting weird with it,i'd get it out of there ASAP and replace it with either OEM fluid or MaxLife,and this time around jack it up high enough to level the transmissions pan rail.
WildcatHemi
Kingwood, Texas
i just did my 8hp with the blau kit. those bottles are a pita!
star_deceiver
Airdrie, Alberta
3.6 Pentastar
Get yourself one of these. It makes adding transmission, transfer case, and differential fluid super easy.
Following the procedure that’s posted everywhere on this site, with a level transmission, my drain and fill with a new pan was a hair less than 5 1/2 litres. I used top tec 1800. No issues after 15000kms.IMG_4051.png
thanks. i will get one. transfer case and diffs are next.
This is my modded garden sprayer,mines the 1 gallon variety,but the 2 gallon versions work good to.I made up a couple differant ends for differant uses,like getting diff fluid back into my wifes Challenger with a diff brace on it.
WildcatHemi
Kingwood, Texas
im doing my next day fluid check. i have the rear end jacked up so that the pan seal surface is level. trans temp is 79f. engine is off. i just removed the fill plug and fluid came out. does that mean im over filled?
Truck needs to be running,and you should go through the shift procedure again before pulling the fill plug. I'm betting you lost a bunch of fluid before you got the plug back in place,lol.
You were right about levelling the transmission,but you messed up by not going through the shift procedure before checking the fluid level .
WildcatHemi
Kingwood, Texas
alright. ran through the sequence. crawled under truck. pulled plug. nothing came out. two pumps on the ravenol jug and fluid started running out. id say she’s good for another 60k.
thanks for the help guys. really appreciate it.
