BigHorn453
- Jul 11, 2013
- 20
- 6
- 2013
- Hemi 5.7L V8
12/13/2013: New Update Available! (Should allow for communication with APPS via mobile).
There is also an update to the uConnect Access APP for your smartphone.
THE FOLLOWING IS REQUIRED IN ORDER TO UPDATE:
- The EXTRACTED Update File (swdl.iso).
- A BLANK USB Thumb Drive (now recommended to be at least 4GB).
(Make sure there are NO files on the USB Drive.)
STEP 1: DOWNLOAD THE UCONNECT UPDATE
Official uConnect Update Site (via VIN Number):
https://rsur.extra.chrysler.com/rsur/Uconnect.do
(If the above site is used, make sure to run the self-extracting .exe which is downloaded, and put ONLY the extracted .iso file onto the USB drive!)
RA3 - v13.48.3 - 8.4A (WITHOUT NAV) [DIRECT LINK]:
https://mega.co.nz/#!f8InhSpQ!BE-A7gbU1dLh5vzay3b-kUCjOIwzm_77jVcTXL-eKmE
RA4 - v13.48.3 - 8.4AN (WITH NAV) [DIRECT LINK]:
https://mega.co.nz/#!C0wSwYAR!VU6xVhyMddpFQs3FDFcksXfAoUlpp28vYzM4sSvr0xc
RJ3 - v13.43.7 - 8.4A (INTERNATIONAL VERSION WITHOUT NAV) [DIRECT LINK]:
https://mega.co.nz/#!20IykCKQ!d2MWhGS3h9OKw_JdRIwDAF_Uggl3oxyfv1TM3Acfs2c
(PLEASE DO NOT SHARE THE DIRECT LINKS!)
STEP 2: TRANSFER UPDATE FILE TO USB DRIVE
Transfer the Software Update File (swdl.iso) to the BLANK USB Drive.
STEP 3: BEGIN UPDATE INSTALLATION
View the instructions for detailed installation process.
LINK: https://mega.co.nz/#!2oAQAYTY!aAQbfF8_zDrcz9gKRTWhTEKkMu1iRaafilZ0hF47Zj8
(If you've updated to any previous versions, it is the same process.)
Follow the on screen prompts to install the update.
The update should take approximately 10-15 minutes to complete.
IMPORTANT INSTALLATION NOTES & FAQ:
- Make sure if you download the update file from a link other than the official uConnect site, that you download the proper file for your radio (RA3 file for RA3 radio, RA4 file for RA4 radio etc.).
- If your radio has been swapped out due to a problematic unit, I highly advise that you attempt the update while your service department is open. If they improperly swapped a radio from another stock vehicle, the VIN may not match and it will ask for an unlock code.
- There is a self-check during the beginning of the installation that will alert you if you're using the wrong region/version.
- If your radio reboots itself at all during installation, this is fine. It should continue the installation process without issue.
- You may notice some settings missing at first, but they will come back shortly (usually within a few minutes).
- Give the radio up to 24 hours to allow it to communicate with other modules and restore everything to how it was.
- If the update fails or seems to hang for longer than 20 minutes on one single module during installation, you can restart the installation. (note: your radio will be inoperative until the installation has been restarted).
Change LOG:
· **Enables Via Mobile software features when released to consumers**.
· **Able to adjust audio balance / fade settings during a VR session**.
· **Correct, condition where user could not exit screen off mode**.
· **Mute button status was not being displayed correctly**.
· **Presets where not shown correctly or were deleted**.
· **Enhancements to POI**.
· **ParkSense tone continuously on**.
· **Enhancement to navigation routing**.
· **Radio display may shows “Please insert USB Stick”.
· **Enhancement made when video is display in radio when using PAL format video disks**.
· **Corrected the temperature slider bar not updating on Manual Temperature Control vehicles**.
· ** Navigation may not start or may lose position**.
· **Rear camera may show a black screen for 3 seconds upon going to reverse**.
· **Enhancements for iPod or iPhone devices that may not start playing after connecting**.
· **iPod would not resume playing after a VR session or phone call**.
· **Removed the cell signal indicators in the SRT and Apps button on non-US vehicles**.
· Radio reset, screen lockup, blank screen or sluggish system response time.
· Compass indicator turns off.
· Touch screen shut down message.
· Radio surround sound will not stay ON.
· Driver memory feature causes Sirius XM failure.
· Loss of radio presets.
· Battery drain - due to radio remains on.
· Uconnect apps don't load.
· AM/FM popping noises and/or static.
· Backup camera display is blank.
· Compass direction may be incorrect.
· Vehicle's Icon changes on the navigation map.
· Loss of vehicle position on NAV map.
· “Vehicle Phone Requires Service” message appears on 8.4” screen.
· Nav turn-by-turn enhancements.
· Nav map guidance enhancements.
· Nav text overlaps in detour menu.
· Nav map, vehicle location enhancements in areas with low GPS signals.
· Navigation shows vehicle in San Antonio, TX.
08-049-13 REV. G -2- (Specific to this version only)
· Screen only displays startup Logo.
· Screen Half Black Half White after update.
· Radio locked up after attempting to update with a corrupted or incorrect USB update stick.
· Phone/Navigation Overlay Screen Freeze (WK only).
· Heated seat controls through radio do not function/display correctly during startup.
· Speed controlled volume not functioning correctly.
· Steering Wheel Control operation corrected at startup.
· Tuner mutes on startup.
· HD now defaults to 'OFF' for reduced complaints about 'channel switching' .
· “LO” temps displayed upon each vehicle start.
· HMI Lock up in SXM mode after ignition cycle.
· Voice Recognition (VR) enhancements.
· Point of interest screen locks up.
· Error message when plugging in iPod.
· Balance/fade setting changes after ignition cycle.
· Clock enhancements.
· Phone book enhancements.
· Rear climate control display frozen.
· Translation enhancements.
· Erratic pop ups in HMI.
· Added Teleprompter.
· Blue tooth, phone, iPod, auto streaming, connecting/disconnecting enhancements.
· Phone quality and pairing enhancements.
· Audio control locked after using VR feature.
· Travel link enhancements.
I DO NOT TAKE RESPONSIBILITY FOR ANY ERRORS THAT COULD POSSIBLY OCCUR. THIS INFORMATION AND UPDATE FILES PROVIDED ARE STRAIGHT FROM UCONNECT.
Change LOG:
