Newbie please help
Dodgeram35
Hi guys new to the forum just got my 99 Dodge Ram 5.2 ext. 4x4. I'm having trouble with it feels like I'm pulling a heavy trailer my tps is reading 12 on the scanner at idle and only 74 when full throttle also shifts funny sometimes around 35-40 like t/c locks and unlocks everything that I have read leds to tps sensor right? Well put a new one on today and still same readings and all the same problems!! Wanna pull what's left of my hair out can't seem to fiqure it out. Please help!!
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Sorry I'm not of use, I'll bump it to the top for you. Look for (dapepper9) or (crazzywolfie), they're both really keen on this.
D
Dodgeram35
Will do I found a couple other members with same problem but it doesn't say if they have solved the problem or not.
crazzywolfie
under the truck
i am not really sure what would cause this or what the readings are suppose to be. have you taken the air cleaner off to verify that the throttle is indeed closing 100%? i think i have read of people ovaling out the holes in the TPS to tweak it a bit but otherwise i am not too sure.
D
Dodgeram35
I will check that but that don't make sense because it won't let me open up all the way either I'm only opening up at three quarters of a throttle
D
Dodgeram35
I have also search the threads and seen a couple other members have the same problem but it doesn't say if they have solved it or not
crazzywolfie
under the truck
i guess that is where ovaling out the wholes could possibly help get the sensor readings back to where they are suppose to be but i would almost wonder if there might be something wrong with the throttle body or something that is causing the readings to not be right.
D
Dodgeram35
Yeah I'm almost certain it's something else causing the throttle position sensor to get that reading do you know if there's any other sensors that are run with that
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
I do believe that the throttle blades are supposed to be open just a smidge even in the "closed" position. This of course will create a reading from the TPS even when you aren't pressing the gas.
As for maximum reading, mine maxes out at something like 66%. I don't think that I've ever read of anyone recording a reading of 100% at WOT. Not sure what it's SUPPOSED to be however.
D
Dodgeram35
From what info I can gather idle should be around 6% and 100% on w.o.t. Feels like I'm pulling a boat lol not sure if this is the cause but from what I can find all points back to tps sensor.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
You can lookup the APPS procedure to reset the throttle position sensor.
D
Dodgeram35
Is that for a gas motor? I thought it was for diesel's only.
Raadz
