Nitto Terra grappler....
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok so on discounttiredirect.com when you search for brand, and you find the Nitto Terra grapplers. In a 305/55r20 size, there are 3 different kinds?? One is priced at $262, the second is $293, and the third is $323??? I don't understand? I don't know much about tires but sizes..... Can some one tell me ways the difference between the 3?? Here's the url...... http://www.discounttiredirect.com/d...byName.do?tmn=Terra+Grappler+AT&typ=Truck/SUV
Droid Incredible 2 on the move!
glass3222
Central PA
Call them to find out.......
There are only 2 that are 305/55R20. The one that is $262 is 305/50R20, so it is a different size. The difference in the other 2 is one is a light truck (LT) and the other P metric. The LT has a slightly higher load index rating, 121 vs 120. 120 is rated at 3086 lbs and 121 is 3197 lbs.
WhiteExpress
Midland, TX
I don't see the $262.
This one is a load range D
This one is a load range E
Depending on what you use your truck for (hauling / towing / heavy loads) I'd get the Es. They then to have a stiffer compound. Longer life but slightly less dry grip.
