No accessory mode, no start?
coolwhip120
CA
2019 Ram 1500 Warlock
Hey y'all, I have a 2018 Ram 1500 5.7 tradesman. Today I tried to turn it on and it wouldn't turnover whatsoever, it won't even go into accessory mode. I got the jumper pack charging right now since I know it's most likely the battery, but is there anything else that would cause this issue? The fact that the power locks and lights work but not accessory mode is making me worried that something else is wrong. Thank you!
EDIT: Here is a video of what's happening --> https://youtube.com/shorts/FQ2L1Y88mvY
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You're starting in the right place. If that doesn't work pull trouble codes and post them (when the battery fails there can be A LOT of codes)
coolwhip120
coolwhip120
CA
Will OBD2 scanner still work if the truck doesn't get into accessory mode? I tried boosting it but it didn't work, same issues. Lights work, power locks work, but the gauge cluster doesn't show accessory mode when I turn the key, nor does the radio come on
coolwhip120
coolwhip120
CA
Check your battery terminals for cleanliness and torque
I did take a peak when I tried boosting it, terminals are spotless and I tightened both cables just to make sure but neither were loose
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Maybe? Not sure honestly.
