Heath Trost
So I am not getting heat on driver side, upper or lower... but I have heat on the passenger side. It isn't warm... it is cold.
I found a video below on the left temp blend control actuator, but I pulled the glove box and I see it moving as I crank the temp down and up... it is moving find.
curious what else should I check?
found this... hoping it isn't it: (HVAC distribution housing needs replacing!!! $2000 fix!! OUCH!!!)
Ram 1500 Blend Door Actuator - 2009-2018+
Quick video on replacing the driver's side blend door actuator. If your heat is cold on the driver's side but hot on the passenger's side, this might be your...
www.youtube.com
No heat on driver side in cabin
Was wondering if anyone else had this problem with their truck. Heat only on passenger side. Got air flowing on driver side but cold. Had it to mechanic and he told me he could only get heat flowing on driver side while hooked up to his computer/code reader. When not hooked up to his...
www.ramforum.com
