No reverse lights
whitedodge
Leander, Texas
5.9 magnum
Checked the bulb and the fuse and they are both good. Checked to see if there was voltage at the socket and there is not any. Where should i go from here?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
check relay underhood, if bad replace.
if not
You need to replace your Neutral Safety/reverse switch. 7/8 deep socket wrench and a part anywhere from 12 to 65 dollars. It is $20 at my autozone. switch and plug are located on the drivers side of the tranny. Switch wears out and is quite common.
Safe bet this should fix your problem:)
