No Sound from a Kenwood Head Unit
brotherRAM
Hey all. I am new to the RAM forum. In fact.....I don't own a RAM truck.
However, my brother does. He has a new-to-him 1999 2500 Cummins. This truck is his new baby.
For Christmas I got him a new head unit, the Kenwood KDC-X997 (Link here).
We did the install ourselves. The head unit powers on fine....but no sound.
His original head unit was the basic unit with a tape deck, not the infinity system.
Any idea what we could have missed? Or any idea where to start diagnosing?
Thank in advance!
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Unfortunately I can't really answer your question, as I'm having the same problem. However if I were you/your brother, I would find a small speaker outside of the truck and take one of the output speaker wires coming out of the head unit (assuming he got a harness adapter to plug in to the OEM ) and wire it to the speaker to see if the head unit is giving sound. If this speaker works then you have a wiring problem like myself. I've seen a black/blue site coming out of the harness that splits out before the harness' plug. I'm not really sure what this wire does, however I believe this is the culprit for my problem, and possibly yours. I'm sorry if this was hard to understand what I'm saying, I'm very tired lol. I wish you the best also if I solve my problem I'll post here just in case your brother is having the same problem
Sent from my HTC6500LVW using Tapatalk
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Sorry for the bad picture but this is the wire I believe is the problem. Does anyone know what it's for/what to do with it ?
Johnn123
Ontario
Black wires are generally grounds. You need that hooked up to some metal for it to work there sir. At least I think thats what that wire is, I could be wrong.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
I don't think it is a ground. I tried connected it to the other ground wire, like someone suggested somewhere and it had no effect. Maybe it needs to be separate I'm not sure. I didn't think it was a ground wire, since it has the blue stripe. But hell idk. I hate f'ing wiring
Johnn123
Ontario
Try touching the metal sleeve the deck is in while the radios on and see what happens. I hate wiring too it confuses me so much lol. Could also be the amp remote wire. It come from the deck or the truck?
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
It's not the remote wire. It comes from the truck. And I have the amp remote wire hooked up anyways. My subs are working great.
Johnn123
Ontario
Id try touching it to metal and see what happens. Im out of ideas after that :p
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
So I tried grounding that wire out and it had no effect at all.
Johnn123
Ontario
Hmm odd. How did you wire it, did you get a harness to clip to the factory connections or hard wire it straight to the deck? Somethings not right here, you getting power to it?
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
I used a clip to adapt to the factory connections. And yes I get power. My subs work. Also I tried connecting it to a speaker outside of the truck sepatate from the wiring harness and it worked. So it must be how it's wired
Dodge96Ram
Long Island NY
Magnum 5.2
If you have power but no sound, double check and be sure you wired the BLUE/WHITE wire on the new stereo into the SOLID BLUE wire on the black plug that clips into the stock harness in the dash. Very common mistake, i see it all the time.
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Yes that was exactly my problem. Huge props to this guy for helping me solve my issues.
Ftank
