No start issue
Ksd1999
Calgary
6.7 cummins
Hey folks, I am new to this forum .
I have a ram 3500 2014 6.7 not starting .
Was running fine a week ago suddenly it cranks but doesn't start .
I am having these electrical codes no luck on them online . Any advice any one encountered these .
Starter cranks the motor for some time then it suddenly sounds like it spins freely after in slow speed.
mtofell
Power supply issues to multiple different items usually points to battery/charging issues but the starter spinning for a while goes against that. Nonetheless, I'd probably start by having the batteries, etc. tested just to rule it out.
K
Ksd1999
Calgary
6.7 cummins
Tested both batteries they test out fine. Also tried starting it with emergency starter same issue . I am thinking dealership is my best bet as i have been unable to find much info on this issue online .
K
Ksd1999
Calgary
6.7 cummins
checked the front fuel filter it has fuel coming in drain valve , hooked diagnostic it has almost the same fuel kpa commanded and actual not much variance.
Rgesse
